Old 04-18-2007, 12:02 PM   #1
help converting vltage
hi all, im living in the uk and will be purchasing a product from the us, i was wondering how or what i need to convert the power supply from usa to uk, i will be purchesing http://www.stealthhydroponics.com/pr...xProd=2&xSec=2 and it is wired for the N. American 110V/120V electrical standard, what do i need to make it work in the uk, any links or info would be much appreciated, im a bit dumb when it comes to electricity
dazboy121 is offline   Reply With Quote
Old 04-19-2007, 11:42 AM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
I do not see specs on the amp draw of the pump or lights. It should be minimal. Something like this should work for you.
http://www.220-electronics.com/Trans...s/stepdown.htm
Confirm the wattage of the pump and lights combine and then get the next largest transformer.
Brik is offline   Reply With Quote
Old 04-19-2007, 11:48 AM   #3
Handyguy
Brik's Avatar
One more thing. If you didn't want to call them and wanted to be absolutely sure there is NO WAY that this thing will draw more than 1500 watts (lights, pump and bubbler combined). So just get the 1500 watt transformer and be done with it. If I were to guess I would say a 500 watt would probably suffice though.
Oh, and if thats an electro-mechanical timer it likely will not work properly due to 50 versus 60 cycles. It will turn but just will be off 10 seconds per minute (slow).
Old 04-19-2007, 03:46 PM   #4
cheers Brik, that helps a lot, many thanks
Old 04-19-2007, 04:20 PM   #5
I have gas!
Clutchcargo's Avatar
You could always head to the local fish store (LFS) and just swap out the air pump and powerhead with ones that will work with your electricity.
Other than the nutrients and test kits there's nothing there that you can't DIY yourself in less than a couple of hours.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Converting a single pole switch to a 3 way Rze Electrical 7 09-13-2011 01:39 PM
Converting a single pole switch to a 3 way Rze Electrical 9 05-02-2011 11:10 AM
Advice on Converting Master Closet to 3/4 Bath Thirdeye Remodeling 9 02-13-2007 08:37 PM
converting coal boiler teresa17603 HVAC 6 10-25-2006 01:46 AM
