-   -   Help converting dryer plug to welder plug. (http://www.diychatroom.com/f18/help-converting-dryer-plug-welder-plug-111409/)
RodBarney 07-20-2011 02:57 PM
Hi I have a 220v 30 amp circuit that was hooked up to a three prong dryer plug. There is a red wire, black wire, and white wire that look to be about 8-10 gauge and then there is a bare wire that I assume is a ground, that is only about 14 gauge. I want to hook up a NEMA 6-50 plug for my welder. I have searched around the web and forum and I have read the white wire would be neutral and not used, only to use the two hots (black and red) and the ground. That doesn't seem correct to use a tiny ground wire on this plug. The bare wire was originally coiled around one of the screws holding the plug to the box. The other three wires were all connected to the plug. Can someone point me in the right direction?
Also, this is probably a separate thread but the wire is stranded aluminum, if it appears to be in good condition is it OK to use?
Thanks, here are links to photos, this is the only way I could figure out how to add them.
http://img135.imageshack.us/img135/8945/dscn3313n.jpg
http://img88.imageshack.us/img88/7955/dscn3312.jpg
http://www.diychatroom.com/%3Ca%20hr...cn3313n.th.jpg
jbfan 07-20-2011 03:06 PM
You can not use that wire on a 50 amp circuit.
You need to replace the wire with a #6/2 romex for the welder.
RodBarney 07-20-2011 03:11 PM
Even if the welder draws less than 30 amps? Sticker on it says it draws 19.8.
Thanks for the reply.
GottaFixIt 07-20-2011 04:52 PM
You can do it. It probably won't meet code and if it burns, your homeowners ins probably won't cover it...
But in theory, all you would need to do is install a 30A double pole breaker at the panel & run the 2 hots to it and switch the white neutral over to the ground lug in the panel.
The 2 hots obviously go to the hots on the plug and the white (previously neutral) to the ground.
RodBarney 07-20-2011 06:08 PM
Thanks for the replies. I'm just going to redo the whole thing or have it redone. Not a real pressing need for a quick fix i guess. I don't really see why it would burn but then again I'm not an electrician either.
mpoulton 07-20-2011 07:13 PM
Why don't you just replace the plug on the welder? That would be easier.
RodBarney 07-20-2011 08:15 PM
That was the original plan, however I couldn't find one readily. I think it ended up being good because when I took the wall plug out it was in really bad shape, the terminals were falling apart. If I had found one and replaced the welder plug it seems like it would be incorrect. I would have a neutral where I should have a ground. If going that route I could just hook up the new plug I have in the same fashion as the old dryer plug but from what I can gather that is wrong.?
mpoulton 07-20-2011 09:39 PM
I don't understand what you're talking about. You had a 30A receptacle, and a welder that requires less than 30A, but has a 50A plug. You would just replace the plug with one that matches the receptacle. That's a standard dryer plug, so it's available at any hardware store or home improvement center (usually as a cord with a molded plug attached). Why would you "have a neutral where you should have a ground"? I don't know what that refers to.
It's good to replace a damaged receptacle, but I would have replaced it with a 30A to match the circuit and put a new cord on the welder.
Techy 07-21-2011 02:13 PM
3 wire dryer receptacle is hot hot neutral(NEMA10-30), welder is set up for hot hot ground(NEMA6-50).
mpoulton 07-21-2011 02:57 PM
Ah, yes. Now I get it. Not a problem. The neutral/bonding conductor in a 3-wire 120/240 connection will work perfectly well as a grounding conductor for a 240V-only connection.
RodBarney 07-21-2011 03:43 PM
Sorry I posted this before I saw the most recent replies. Ignore.
That's probably because I'm doing a bad job explaining it because I don't really know what I'm talking about. Let me really beat this to death.
I did go to home depot and my favorite ACE hardware store that always has everything I need and neither place had the plug.
When you say replace the plug with a thirty amp to match the circuit I get it, makes perfect sense. So i would hook up the plug just as it was.
Then I find a plug for the welder that fits the wall outlet i just installed. The welder cord has two hots and a green ground. then I hook up the plug. But the green ground is now plugged into the white neutral in the wall, right? That's what I meant by a neutral in place of a ground. Someone above said to change the neutral over to ground at the box, then its seems to me it would be how it should be.
RodBarney 07-21-2011 03:49 PM
Thank you. Somehow it took me two paragraphs to say just that.
GottaFixIt 07-21-2011 06:35 PM
It would be. It would be functional. IMO, when protected with a 30A Breaker, it would also be safe for use (assuming your connections are sound). Code takes into consideration other factors, such as - if you left tomorrow, and an electrician went to chance the plug back, you'll have changed things to ways not intended.
You could indicate that you've changed the neutral to ground by marking with green electrical tape. Still may not meet code, but at lease it would indicate that it's been changed...
CheapCharlie 07-22-2011 02:48 AM
Did the welder come with a 50A plug on it? If so you'll need to plug it in to a 50A receptacle. I wouldn't change the 50A plug to a 30A plug. It's obviously designed that way.
mpoulton 07-22-2011 04:21 AM
He says the rated current is 19.8A. A 30A plug/circuit is more than sufficient in that case. Just because the manufacturer chose a 50A plug doesn't mean a 30A plug would be inadequate.
