Help Constructing A Heated Box. - Electrical - DIY Chatroom Home Improvement Forum
Old 02-02-2011, 10:54 AM   #1
Help constructing a heated box.
Afternoon!
I need to create a metal box with an adjustable temperature range for an experiment one of the researchers at work wants to run. It needs to hit at least 200 degrees. I planned on using strip heaters for the heat, but am having trouble figuring out how to control the temperature. Most of the strip heaters I have found online reach up to 900 degrees. The steel box I'm having our shop build for us can handle that and I'm sure at some point, one of the R&D guys here may want to reach that level some day, so I'd like advice on what to use that can cover a wide range.
Thanks in advance!
Vic
sgthanley is offline   Reply With Quote
Old 02-02-2011, 12:30 PM   #2
Head over to the Omega Engineering site and start reading.
http://www.omega.com/temperature/Z/pdf/z110-114.pdf
Matsukaze is offline   Reply With Quote
Old 02-03-2011, 02:17 AM   #3
Scared Electrician
Saturday Cowboy's Avatar
how about using an old oven?
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 02-03-2011, 07:49 AM   #4
the controllers at the Omega site looks like they'll work.
Old oven wont work. It's for an experiment at using one of our thermal sensor systems, so the box is being constructed at our shop. Steel box, 1/2" thick, 4'x2'x2'. Needed a way to heat it accurately, but looks like the Omega controllers will do the trick.
Best place to learn about and purchase PEX for heated floors? RUMBLON HVAC 0 01-03-2011 12:20 AM
Heated Floors Affecting Grout question Ted Uy Flooring 12 08-29-2009 01:45 PM
Heated tile ... really worth it? alvanos Flooring 27 01-11-2009 01:35 PM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 03:51 PM
20" Porcelain Tile with heated wires - Please help! jmille72 Flooring 3 11-29-2007 09:38 AM
