Old 01-04-2013, 05:32 PM   #1
Help connecting range replacement power cord
The cord on my range needs to be replaced and I am unfamiliar with how how to remove connector piece from old cord and install on my replacement. I attached pictures to give a better idea of what type of connector I am talking about- the three wires insert into three holes but I need to remove/replace the small metal sleeve things that go on the ends of wires before inserting into the plastic connector end. Is this a piece I can buy at the hardware store and simply replace or is is something specific to my range and would need to be ordered from a parts store? Or better yet can the one from the old cord be reused on new one?
Help connecting range replacement power cord-dsc07312.jpg   Help connecting range replacement power cord-dsc07313.jpg   Help connecting range replacement power cord-dsc07314.jpg   Help connecting range replacement power cord-dsc07315.jpg
designSTL is offline   Reply With Quote
Old 01-04-2013, 05:45 PM   #2
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Looks like something specific to your range. Maybe you could just remove the connector and use some other method to connect the two.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 01-04-2013, 06:05 PM   #3
A "Handy Husband"
rjniles's Avatar
I assume this is a gas range. I would cut the connector off the stove end and connect the cord to the stove wiring with wire nuts.
If you are not comfortable with that I would order the exact replacement cord (with connector) from the manufacturer.
Coastal South Carolina
Old 01-04-2013, 07:21 PM   #4
Thanks for the responses. Here is my next question- if I go with wire nuts and connect the cord is it ok that the connections will not be contained within a junction type box? I just installed a cord on my new dishwasher that way but there was a steel box with a cover on the underside of dishwasher specifically for this purpose. What are my options?
Old 01-04-2013, 07:29 PM   #5
http://www.radioshack.com/product/in...ductId=2103986
cut the old wire into a pig tail and put into this terminal strip and the connect your new cable to the matching color on the terminal strip, now you can change cords any time you need to.
redman88 is offline   Reply With Quote
Generator L14-20 Power Cord EPenn Electrical 7 11-10-2012 01:47 PM
Range Cord Acceptability chronojosh Electrical 11 06-28-2012 06:08 PM
Samsung TV Extension Power cord Olgian77 Electrical 31 06-25-2012 06:14 PM
power steering pump replacement issues joey219 Automotive Repairs 2 10-08-2009 04:14 PM
Power cord question bucksone Electrical 15 04-10-2009 10:56 PM
