Old 08-07-2012, 02:49 PM   #1
help with connecting existing wiring to a ceiling fan to a constant hot outlet
I installed a ceiling fan in garage. have 2 sets of wires. one from the switch that is black, red, white, and ground. these i have connected to fan red to fan blue and black, white to white and ground to ground. now the out lets do not work. have a white black and ground set of wires on outlet side and the extra black wire from switch side. I want the fan to work of the light switch and not constant hot which is what happens when i connect the black wire. help
alycia is offline   Reply With Quote
Old 08-07-2012, 03:03 PM   #2
Electrical Contractor
Do you have one switch or two?
You can combine the fan and light to one switch and feed the rest of your receptacles with the black wire.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Guidance needed with existing wiring - Ceiling fan install rickkrause2001 Electrical 4 03-23-2012 04:33 PM
Converting switch to switch & constant power outlet BCeagle08 Electrical 4 01-29-2012 10:34 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 10:13 PM
existing ceiling fan wiring old house hoyt2 Electrical 1 07-16-2010 12:49 PM
wiring new outdoor outlet off exisint outlet hellothere123 Electrical 2 07-10-2009 10:44 AM
