-   -   help with connecting existing wiring to a ceiling fan to a constant hot outlet (http://www.diychatroom.com/f18/help-connecting-existing-wiring-ceiling-fan-constant-hot-outlet-152949/)
alycia 08-07-2012 01:49 PM
I installed a ceiling fan in garage. have 2 sets of wires. one from the switch that is black, red, white, and ground. these i have connected to fan red to fan blue and black, white to white and ground to ground. now the out lets do not work. have a white black and ground set of wires on outlet side and the extra black wire from switch side. I want the fan to work of the light switch and not constant hot which is what happens when i connect the black wire. help
jbfan 08-07-2012 02:03 PM
Do you have one switch or two?
You can combine the fan and light to one switch and feed the rest of your receptacles with the black wire.
