Help With Conduit Bend - Electrical - DIY Chatroom Home Improvement Forum
Old 09-05-2013, 12:25 PM   #1
Rewards Points: 103
Help with conduit bend
Guy, I have a conduit run that is sitting about 1/2 an inch below my finished ceiling height, where it bends 90 to go to the second level it is behind a vent stack and I have no access, the other way goes into a exterior wall with also no access, Is there any type of tool that can slip into this tight area to bend this run up a half inch? I need to install drywall on the blocking you see. I hope this picture helps, thanks in advance for any help
Mike
Mlorek is offline   Reply With Quote
Old 09-05-2013, 12:44 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
You could use some 1 x's for furring strips.
I doubt you could notice that little bit of a slope, if so add them across the ceiling.
You could also just do a "field bend" and get it out of the way 1/2"
wirenut1110 is offline   Reply With Quote
Old 09-05-2013, 01:07 PM   #3
Rewards Points: 103
Thanks wire nut, I was able to field bend it out of the way the half inch, appreciate it man!
Old 09-06-2013, 11:28 AM   #4
Rewards Points: 446
The threads on that cleanout are looking nasty.
old_squid is offline   Reply With Quote
Old 09-06-2013, 11:35 AM   #5
Rewards Points: 510
That's ok, after it get's covered with the sheet rock, you'll never see it.
PVC conduit questions powertoolguy Electrical 4 08-28-2013 06:30 AM
Total Degrees of Bend in Underground PVC Conduit tedallen Electrical 12 03-29-2012 08:02 PM
Calculating 90 degree conduit bend Richo Electrical 7 02-01-2011 11:01 PM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
Conduit Bend Calculation Help johnny5 Electrical 9 01-20-2009 10:35 PM
