Help With Code Violation - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 10-20-2008, 11:39 PM   #31
Originally Posted by thekctermite View Post
A testament to your local codes authority.
That's pretty much all of Oregon that I know of. While I rarely pull a permit on anything I do on my homes sometimes the customer wants a permit.
I did some windows for a guy and drew my plans on a piece of paper and he approved it right there. I had to pull out a 12 foot wall, install a header, put in the window and seal it up.
He never came by until the job was done and I had been gone for a week. I just emailed him pictures of the work, mainly the structural part.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-21-2008, 09:00 AM   #32
Rewards Points: 1,910
In small town Southern Il. a homeowner can just draw up there own plans and submit them as long as you were following the prescriptive method. In fact they even had preprinted wall section diagrams that stated minimum requirements and had blanks for the homeowner to fill in. Very simple if you're not doing anything that requires engineering.
Old 10-21-2008, 09:27 AM   #33
Registered User
Termite's Avatar
Yup, we do the same thing on the smaller, easier jobs. Big renovations (moving loads, firewalls, etc) require stamped plans, or an engineer's stamp on plans drawn by the homeowner (very common).
Old 10-21-2008, 01:45 PM   #34
chatterbass's Avatar
Here's some straight talk:
You say you can't afford $10,000 to fix the wiring but you've managed to afford to lose $1000 per month in rent for the past year. If you are any good at math you will figure out that you've already "spent" $12,000 in lost rent for nothing in order to avoid spending $10,000 for something. And you are now continuing to lose $1,000 a month for nothing. Hopefully you'll figure it out before you've lost $24,000 to avoid a $10,000 expense.
a 1000.00$ a month is a little different then 10,000$ in one shot.
sorry so late on the comment but that just bugged me.
good luck on what ever it takes to get it done.
chatterbass is offline   Reply With Quote
Old 10-21-2008, 01:51 PM   #35
Yes, $1000 a month is a lot more.
Old 10-21-2008, 02:23 PM   #36
RippySkippy's Avatar
This post should be a sticky right under the general heading "does my job need a permit" for those that need the encouragement. I really wish the OP the best...at least for now it looks like all parties are being reasonable at least for the time being...that's a bonus!
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
What's the ICC Electrical Code? Chuck Electrical 7 02-20-2013 10:19 AM
Code Violation or not? Stubbie Electrical 17 04-17-2008 09:33 AM
Building code violation fetzo Building & Construction 18 03-22-2008 02:42 PM
code violation? krw1957 Electrical 6 12-11-2007 06:16 AM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 01:47 PM
