Old 02-17-2010, 12:01 AM   #1
Help changing two to three prong switch controlled
Help changeing two to three prong swtch controled outlet. I have
three(3) white weires in one side and one(1) red on the other.
Changeing to grounding duplex receptacle.
MoFo is offline   Reply With Quote
Old 02-17-2010, 12:57 AM   #2
nap
You talking to me?
nap's Avatar
you can't just change to a 3 prong receptacle.
you either need to install a ground wire or install a GFCI recep or leave it 2 prong.
Old 02-17-2010, 02:08 AM   #3
You cant just run a ground unless you are using emt. I don't think he has emt. So the best way for you to have a three prong receptacle is to make it a gfci ungrounded.
Chevyman30571 is offline   Reply With Quote
Old 02-17-2010, 02:18 AM   #4
nap
You talking to me?
nap's Avatar
Originally Posted by Chevyman30571 View Post
You cant just run a ground unless you are using emt. .
actually, yes, you can. it's in the code. You do not even have to go to the panel. the other options are in the code as well.
and if you have conduit, you do not need another EGC. The conduit is acceptable as an egc.
Old 02-17-2010, 03:38 AM   #5
Thanks for the help works great. ~<;•}*
Old 02-17-2010, 09:25 AM   #6
So your saying that if I have say a 12/2 romex with no ground just a 2 wire going to my outlet I can run a single wire from the panel to the outlet and make it a ground? If this is what you are saying than no this is not allowed. You would have to run an entire new cable.
Old 02-17-2010, 09:48 AM   #7
Xtreme DIY'r
Read 250.130
Old 02-17-2010, 10:00 AM   #8
nap
You talking to me?
nap's Avatar
please refer to what scuba dave referred to in the NEC.
I am curious as to what expertise you claim so as to be able to quote legalities of an installation. Are you a pro electrician, like me? Are you simply a very well versed layman like Scuba Dave?
or are you just shooting from the hip and making incorrect statements because of that?
Old 02-17-2010, 10:40 AM   #9
Just call me Andrew
The applicable section from the NEC...
Andrew
secutanudu is offline   Reply With Quote
Old 02-17-2010, 10:45 AM   #10
nap
You talking to me?
nap's Avatar
thanks for posting that secutanudu
Old 02-17-2010, 10:58 AM   #11
Just call me Andrew
Sure. Posting it was easy...thanks Dave for listing the section
Andrew
Old 02-17-2010, 11:35 AM   #12
nap
You talking to me?
nap's Avatar
yes, Dave deserves thanks but since he is a mod and I am a devout antidisestablishmentarionist, I simply cannot thank him openly.
seriously though, thanks to both as I was just too lazy to look it up and I just know chevyman was not going to take my word for it.
Old 02-17-2010, 11:39 AM   #13
nap
You talking to me?
nap's Avatar
I just noticed something.
Dave, where did you get a picture of me during my electrical apprenticeship?
Old 02-17-2010, 11:56 AM   #14
Electrical Contractor
sshh! Just wait until he puts up the picture when you turned out.
The Mods are all seeing and all knowing!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 02-17-2010, 12:05 PM   #15
nap
You talking to me?
nap's Avatar
well, I figure I'll just reveal myself.
I'm the guy on the left and what you see is a direct result of the pic dave has:
changing 3 prong receptacle to 4 prong WendyS Electrical 12 01-17-2010 09:59 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 09:37 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 02:26 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 06:06 PM
