HELP! Ceiling Light Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-13-2011, 07:24 PM   #1
Exclamation
1920's era house.
I had a ceiling light fixture operated by 2 switches. I needed to remove 1 switch and replace the light fixture. So I cleared everything out of the box except for the BX cable feeding power to the box.
What I have in the box now are 3 wires. A white, a black and a red that was previously unused.
I have 2 questions.
First - which wires to I attach to the new fixture (it has white, black and ground(green)
Second, which wires do I attach the old switch to?
Joeychgo is offline   Reply With Quote
Old 03-13-2011, 07:26 PM   #2
Electrical Contractor
kbsparky's Avatar
What's in the other switch? How many wires attached to it, and how many wires are connected together and tucked in the back of the box?
-KB
Old 03-13-2011, 07:27 PM   #3
None - everything is dissasmbled. The old box is even gone now (since it was part of the light fixture)
Right now I am just looking at a cable with 3 wires. The red was previously unused.
One switch is gone completely as I needed to remove it. The other switch is not connected to anything.
Old 03-13-2011, 08:46 PM   #4
Licensed electrician
Rewards Points: 1,234
You may have removed the box that brought the power into the switches. Without knowing where the remaining cable goes or if it is hot it will be very difficult to give you any help.
Old 03-13-2011, 09:04 PM   #5
Um - no... ALL I have left is the wire that powered the box. As I said... What I have in the box now are 3 wires. A white, a black and a red that was previously unused.
There is no power running to the remaining switch.
wiring ceiling fan to light switch cshsr Electrical 10 07-20-2009 05:08 PM
humming sound from wiring in the ceiling to a light fixture njvcl Electrical 3 05-12-2009 11:00 AM
Question with wiring up a flood light. SuperAkuma Electrical 6 09-20-2008 11:58 AM
Ceiling fan wiring question steve b Electrical 10 04-02-2008 01:57 PM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 08:51 AM
