Help Ceiling Fan/light Switch Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 12-21-2011, 02:41 AM   #1
Help ceiling fan/light switch wiring
Hi,
I need to replace a 2 unit ceiling fan/light switch. The old switch is
The left one has 2 wire (red/black), the right one has 2 wire both are black .
My new switch is
with wiring diagram in the back
Tried many combination but still can't get it work. please help. thanks a lot.
kukockuo is offline   Reply With Quote
Old 12-21-2011, 03:48 AM   #2
Electrical Contractor
kbsparky's Avatar
The "old" switch on the right appears to be a remote transmitter, which works in conjunction with a receiver unit mounted in the fan itself.
Unless you remove the receiver, and direct-wire the connections at the fan, nothing will work, unless you replace the transmitter switch with another compatible unit.
-KB
Old 12-21-2011, 07:07 AM   #3
Agreed. I think your best option would be to remove the transmitter/receiver combo, or go with a new set.
The remote transmitter has a fan and light switch on it...
Which switch controlled what in the past?
fuzzball03 is offline   Reply With Quote
Old 12-21-2011, 03:54 PM   #4
KB & Fuzz - thanks to your reply.
In the past, I only use the switch on the right to control both fan and light.
Since my new switch won't work. Which solution will be easier? remove the receiver on the fan or buy another transmitter switch?
Old 12-21-2011, 04:25 PM   #5
I think that's a question you need to answer yourself.
We dont know where the receiver sits(likely in the fan canopy) or how or what it would take you to gain access to it.
We also dont know what is or is not compatible.
Old 12-21-2011, 08:46 PM   #6
any idea how to remove the receiver and re-wired?
I opened the canopy and saw 4 set of wired connect by connector
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
Wiring a single pole wall switch to a ceiling fan and light. How ? Larry Lambert Electrical 3 03-08-2011 03:52 PM
Wiring Bathroom fan to dual switch joerob25 Electrical 3 12-15-2010 10:11 AM
Wiring a Ceiling Fan to a Switch that also Controlls Hot Switch timsarah Electrical 6 03-30-2010 08:14 AM
Hunter Fan/light and dual switch wiring nashua Electrical 2 01-02-2010 10:40 AM
