Help With Cat5 - Electrical - DIY Chatroom Home Improvement Forum
Old 10-31-2012, 06:38 PM   #1
Rewards Points: 105
Help with cat5
Can someone help me here? I'm not sure what I need to do to connect this. Do I even have the right materials?
Thanks!
andybeck is offline   Reply With Quote
Old 10-31-2012, 06:47 PM   #2
Sparky
Rewards Points: 510
Are you trying to use this for telephone or data?
Techy is offline   Reply With Quote
Old 10-31-2012, 06:58 PM   #3
Electrical Contractor
kbsparky's Avatar
Looks like a 4-line phone jack.
You need a CAT-5e data jack for computer LAN wiring
-KB
Old 10-31-2012, 07:03 PM   #4
Master Electrician
Rewards Points: 3,960
If you are using it for a single phone line, connect blue to red and white/blue stripe to green.
brric is offline   Reply With Quote
Old 10-31-2012, 07:16 PM   #5
Rewards Points: 105
Trying to use it for data. The female end on the plate is larger than a phone line and meant for data I believe.
Old 10-31-2012, 07:47 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,252
That is not a data jack. You need a RJ45.
Coastal South Carolina
Old 10-31-2012, 08:00 PM   #7
Rewards Points: 105
I don't mean to argue but I tried an Ethernet cable in the port and it fits. It also said on the package data/television.
Old 10-31-2012, 08:07 PM   #8
Rewards Points: 6,652
Used them before for data jacks, but not good if doing Gig speeds. Get some RJ-45 Keystones and plates and make it simple.
Old 10-31-2012, 08:42 PM   #9
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
Just so you know. It will work, but it's a crap jack for data. A real RJ-45 would work much better.
Old 10-31-2012, 08:42 PM   #10
http://www.iplocation.net/tools/rj45-wiring.php
See the part labelled: RJ45 Color-Coded Scheme
Old 10-31-2012, 08:46 PM   #11
Rewards Points: 105
Great, thanks all! I'll get one tomorrow and give it a shot.
Is it okay to splice "live" cat5? Tryvidy Electrical 8 02-13-2012 01:54 AM
Running cat5 wire over ventilation / heating ducting ajtool General DIY Discussions 7 06-11-2010 12:45 PM
cat5 timchi29 Electrical 7 07-26-2009 09:50 PM
Can I run CAT5 thru the electrical RMC? BradG Electrical 13 04-03-2009 11:31 AM
How to route cat5 & coax? radon Electrical 2 02-20-2008 02:49 PM
