Help - Can't Find The Correct Low Voltage Lighting Transformer - Electrical - DIY Chatroom Home Improvement Forum
Old 03-24-2011, 06:11 AM   #1
Help - can't find the correct low voltage lighting transformer
We have lights installed under our kitchen cabinets and the low voltage transformer in one of them is going bad. It's a 12.8V Model DR16S (not even sure who the manufacturer is though), but I can't seem to find it anywhere? Who sells these components?
Thanks - Best regards,
Sherm
Sherm is offline   Reply With Quote
Old 03-24-2011, 07:27 AM   #2
Rewards Points: 6,652
partsexpress.com, or even Radio Shack may be able to order through their parts system. Also check with the manufacturer of the lights.
Old 03-24-2011, 09:14 AM   #3
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
Your under cabinet lighting is manufactured by Kichler Lighting. You could probably call their tech support and order a new transformer.(www.kichler.com)
HIVOLT is offline   Reply With Quote
Old 03-24-2011, 09:21 PM   #4
Yep, exactly! I may have a problem though. After posting this thread, I found this ... http://forum.doityourself.com/lighti...on-lights.html
Originally Posted by TheMike
I have the exact same problem, exact same model. I trouble shot every link from the switch to the light bulbs. I dismantled the light to a point and turned it on. I wiggled every connection in the light itself and only when I pressed on the black transformer (put pressure on it) did the light come on. It stayed on all day. I turned it off that night when I went to bed.
Next day, flip the switch and nothing. Press on the black transformer in the light housing and it comes on. So....it's definately the transformer.
I'm in the process of finding just the transformer as there is no need to replace the whole fixture.
Light: K-10566-WH
Transformer: DR16S
If I can find an exact replacement it's a piece of cake to swap out. The transformer is about half the size of a deck of cards and is held in place by double sided tape. A couple of wire nuts and it's done.
Now to shop.
And, there was no solution posted. I've already done a pretty good amount of searching ... so, I may actually have to buy another light!?
HELP! Can't Find Fault with Lighting Loop RussellJColvin Electrical 12 08-07-2008 02:10 PM
Track Lighting newbie questions GFW Electrical 1 04-18-2008 10:23 PM
Generator Output Question gimmeda8 Electrical 11 03-06-2008 11:15 AM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 12:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 08:06 AM
