Old 08-08-2007, 09:24 PM   #1
Unhappy
Help A/c Not Blowing
my central air comes out cool but with no force.
DARINS_MOM is offline   Reply With Quote
Old 08-08-2007, 09:44 PM   #2
Eibwen
Check the filter and see if its in need of a change out.. If thats not it and your getting cool air out of the vents but no real airflow, its probably the fan in the air handler.
Sammy is offline   Reply With Quote
Old 08-09-2007, 02:15 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
I'm not an HVAC technician, but I have a 1998 Carrier heatpump system.
Whenever I run into a weak air flow situation, it always means that the blower (circulating) fan motor control has gone out.
It happens so frequently with this Carrier heatpump design (once a year or least every other year), that I keep a spare motor control (about $200) and learned how to replace it myself.
That may be the problem, if you don't change the filter monthly.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 08-09-2007, 02:29 AM   #4
Last year, I had that same problem and had to have the motor replaced. It would have cost hundreds, but I took out a home warranty insurance ($39 month) and had it fixed by a lic. AC repair company for a $45 fee.
Hope
"Hope" is offline   Reply With Quote
Old 08-09-2007, 09:28 AM   #5
yummy mummy's Avatar
I have had the same problem, twice now and it was determined that there was a refrigerant leak.
yummy mummy is offline   Reply With Quote
A/C not blowing air mmorand HVAC 4 06-16-2007 12:31 PM
Registers are not blowing air Macgyver HVAC 6 01-19-2007 03:39 PM
Light keeps blowing econdave Electrical 3 01-15-2007 09:42 AM
blowing out the water lines jerry1967 Plumbing 6 10-26-2005 11:34 AM
my ac keeps blowing boards on my heil furnace sally HVAC 2 07-23-2005 08:14 PM
