Help Burying Conduit. - Electrical - DIY Chatroom Home Improvement Forum
Old 07-18-2008, 09:14 PM   #1
Help burying conduit.
Hi all. I want to add an outlet on the opposite side of my patio. Just one outlet, to plug in some outdoor lights, rather than having the cord from the lights come acroos the patio to the outlet on the house.
All I want to do is bury the conduit, so I can finish the patio, but I'm not sure what size conduit to use for just an extra outlet. The distance underground will be 11 feet, and I'm not sure how deep to bury it.
I'm in northern California, with no frost.
Thanks all!
I ask the stupid questions.....but I expect the smart answers.
Wanttodoitright is offline   Reply With Quote
Old 07-18-2008, 09:28 PM   #2
electrical contractor
Rewards Points: 150
what type of patio? concrete, brick, etc??
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 07-18-2008, 10:53 PM   #3
Actually, I'm going to run it next to my concrete patio, but I am pouring a walkway to the patio, and the conduit go under that. The walkway is only 2 feet wide, so the conduit will be under my yard, for 9 of the 11 feet.
Old 07-19-2008, 06:50 AM   #4
Master Electrician
JohnJ0906's Avatar
Thanks all!
If you use PVC conduit, 18" minimum depth. Please use electrical PVC with electrical 90s - if you use plumbing fittings, it is VERY difficult to get a wire to pull through.
Personally, I would use " PVC. Larger than you need, but A) easier to install the wire, and B) room for future additions.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 07-19-2008, 07:33 AM   #5
Rewards Points: 150
Agree with John 100% always run bigger pipe than you think you need, easier to pull and future room.
Jimmy
Conduit Spacing / Separation smitty286 Electrical 3 04-08-2008 10:11 AM
Conduit Fill & Ampacity capndave Electrical 37 03-26-2008 02:16 PM
Conduit issues - help needed nymackem Electrical 19 11-05-2007 06:45 AM
Conduit through basement wall. bdalekid Electrical 13 01-31-2007 08:35 PM
