HELP: Blown Electrical Outlet? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-12-2012, 10:20 AM   #1
Mystified by this one, last night my wife plugged the hairdryer into an outlet in our bedroom. The TV was on and a few other lights.
Something blew, and 2 of the 4 sockets in the room appear to be dead. There are also 3 other outlets dead in total in 1 other room.
I have no fuse box that I know of - I went to check my panel and none of the circuit breakers were switched. Just to check, I have reset every single one in the house multiple times, including the main breaker to the house (with everything unplugged upstairs) and nothing... nada.
Any help or suggestions? House is only 5 years old, never had issues that went beyond resetting a switch on my panel before.
THANKS!
Ian
hazey313 is offline   Reply With Quote
Old 11-12-2012, 10:25 AM   #2
Rewards Points: 13,724
Could be several things.
Look for a tripped GFI, it could be most anywhere, most likly in the bathroom.
Look at the breakers, do any have a red buttom on them. They may be arc fault breakers.
One loose back stabed outlet can also cause this to happen.
hazey313 (11-12-2012)
Old 11-12-2012, 10:33 AM   #3
Rewards Points: 6,652
First what idiot wired the bedroom outlets to the bath outlets. It is not a blown GFCI, but most likely a backstabbed outlet, that the Neutral has come loose on.
You are lucky that your house did not catch on fire. Get an electrician to straighten the mess out.
Old 11-12-2012, 10:43 AM   #4
update
greg - everything in the bathrooms is working and no GFI's are tripped so I don't think that is an issue.
greg & joe - thanks for the tip. I will check the back of the outlets now... what a pain in the arse!
Old 11-12-2012, 10:47 AM   #5
Pure Genius
Rewards Points: 150
My money is on a tripped arc fault breaker.
Dierte is offline   Reply With Quote
The Following User Says Thank You to Dierte For This Useful Post:
Old 11-12-2012, 11:19 AM   #6
hmmmm
opened up all 8 outlets that are dead, nothing seems out of the ordinary (all wires connected, no loose or disconnect ground)
assuming it is an issue with this arch fault breaker (I do have one in the basement), any further suggestions on how to remedy before I assume it's faulty?
Old 11-12-2012, 11:26 AM   #7
Check all of the connections on the outlets to fix them if they are backstabbed, vs having the wire screwed down, then once you have done that, you can turn back on the breaker.
But again, what idiot wired that place with the bath & bedroom together? Also, where do you live, because codes are different between the U.S. & Canada, and other countries.
Old 11-12-2012, 11:27 AM   #8
fixed!
It was the AFCB after all, I wasn't fully shutting it off then resetting!
This brings up another question though, is it normal to hear a humming from my box once I reset it... it's actually quite loud. as soon as I reset I heard the humming. normal?
thanks everyone for your help!
Greg - the bath and bedroom were not together. I think that was implied by another response on this board - but nothing in the bathroom shut off when the bedroom tripped last night.
The Following User Says Thank You to hazey313 For This Useful Post:
gregzoll (11-12-2012)
Old 11-12-2012, 11:30 AM   #9
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
Push the test button and see if it trips and the humming gos away.
You may have to replace the breaker.
Old 11-12-2012, 11:39 AM   #10
Also check the connections in the panel.
Tags
blown fuse , circuit breakers , electrical
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
Which box for flush-mount (in-wall) outdoor electrical outlet? plambert Electrical 2 10-27-2011 03:05 PM
Existing concrete slab has electrical and cat5 outlet. Would like smaller faceplates. noone Electrical 5 10-17-2011 02:29 PM
2ft Wall/Hallway Electrical Outlet Question?? hatchekc Electrical 1 07-17-2010 08:51 PM
Help with adding electrical outlet bowanna03 Electrical 5 05-23-2010 07:00 PM
