I have searched and read many posts on the same thing but I could not find anything that sounds like my current setup so I took some photos. I am assuming all the wires are here and I dont need to pull any new ones. Right now the fan and light are on the same switch and I want to put them on a double switch so I can turn them on/off independently.
I did try to hook it up and just succeeded in having one switch work and still turn on both at the same time so I dont know what im missing here. thanks!
Are you sure about which wires are hot with the switch off? If this was wired sensibly, those black wires near each other on the original switch would be the power to the fan and light, and the other black wire at the bottom would be the incoming power. If that were the case:
The incoming hot goes to one of the black LINE screw on the new switch. There's probably a tab connecting the two LINE screws, don't break it off.
The other two black wires go to the brass LOAD screws on the other side of the new switch.
yes, I disconnected the wires, flipped the power back on and tested them, that is the hot wire. ( i put them back exactly how they were (sounds like its not right to begin with...
so here is what I tried, I attached the incomming hot to one of the black screws on the new switch, and the other two black wires on the brass screws, and the ground where it is supposed to go...anddd
still only one switch on the two switch assembly works and both fan on the celing and light on the wall turn on at the same time..
but then i broke the tab (stupid mistake to see if that made a diff...so now i need another switch) (well at least im learning..
It will be a few days before i can get up and see whats behind the fan if that is the next step.
I am in michigan i dont think it is code to have them on the same switch here...
You'll have to run a 2-wire cable from the new switch you want to install (Sw2) to either the fan box or the light box. Problem is, I don't know if the cable runs from the switch > fan > the light, or from the switch > the light > the fan.
Can you take pics of wires coming from the fan box, and from the light? Or at least, describe what you see from these locations.
Read my other post.
If that is the hot wire connected to the back stab, with another wire connected to the same screw, you feed in and out the hot.
The wire on the bottom is the feed to the light, and you only have one wire feeding the lights, so the switch will turn on both.
You need another wire to seperate the fan and light.
From what I see, you will need a piece of 12-3 wire going from your switch to your fan. You will have a black, red, and white wire, plus the ground.
The black wire should feed your light, and be wired to one swtich. The red wire should run to your fan, which will be on the second switch. I would assume there will be a tab between the hot coming in and out, but there should not be one between the wires that run to your fan/light.
What we need to see to help you out is a picture of the wiring behind the fan/light assembly, and the front of the switch would be helpfull as well. It could be that second black wire that you said does nto do anything does not go to your fan, but to something else, like an outlet or another light, or to nothing at all.
Hope that helps you, and if I am wrong, someone please correct me
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
