Help With Adding Electrical Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 05-23-2010, 05:24 PM   #1
Rewards Points: 77
Help with adding electrical outlet
I am looking to add an oultet for behind my lcd tv. I have an existing outlet below it just want to tap into that outlet and run another outlet up higher. One question I have is can i use yeloow coated wire it is marked as Type NM-B 12-2. Can I use this to tap into the exisiting outlet and feed it up and install an old work electrical box and new outlet.
bowanna03 is offline   Reply With Quote
Old 05-23-2010, 05:27 PM   #2
What is the current circuit rating ? 15a or 20a ?
Old 05-23-2010, 05:33 PM   #3
Rewards Points: 77
For what? The Tv or the wire?
Please help guys
Old 05-23-2010, 06:26 PM   #4
Electrician
Rewards Points: 794
I would have to say yes, no convenice outlet will be 30A so #12 would cover a 20A or a 15A circuit. In my opinion mixing wire size on a run is tacky and should be avoided. It doesn't sound like you are running very far so if it is a 15A circuit i would go buy some 14/2. If it is a 20A circuit you need to use 12/2(14/2 would not be allowed).
darren is online now   Reply With Quote
Old 05-23-2010, 06:32 PM   #5
Rewards Points: 77
I would buy 14/2 but I have a roll of 12/2 and I have to go maybe up 2-3 ft up the wall. Would that be ok to do
Old 05-23-2010, 07:00 PM   #6
Registered User
Rewards Points: 5,514
Is the old box 18cu.in. or larger OR 2 or more 12/2 already there?
Be safe, Gary
Adding outlet for above stove microwave bobbysan Electrical 6 04-28-2010 07:01 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Adding an outlet BimmerRacer Electrical 5 09-02-2009 08:02 AM
Adding additional outlet. Pigtail four sets of wires? svanhess Electrical 5 07-12-2009 10:27 PM
Adding an electrical outlet box helpless handyman Electrical 14 07-06-2007 07:59 PM
