Help With 45 Amp Cooker Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 07-04-2009, 01:51 AM   #1
Help with 45 amp Cooker Switch
Hi, new to this forum, have just replaced old 45amp cooker switch with new one with neon on light. have wired it up, however swith works ie. off in off position and on in on, but the neon light stays on which ever postion the switch is. Help required please.
Andy
gen203 is offline   Reply With Quote
Old 07-04-2009, 08:19 AM   #2
dSilanskas's Avatar
So without a wiring diagram or knowing what kinda switch it is. I am guessing here but try to switch the two black wires around.
dSilanskas is offline   Reply With Quote
Old 07-04-2009, 10:23 AM   #3
The neon light with its series resistor has be to be wired across the load. It seems to be wired across the source.
The third option is to wire it across the switch contacts, so it will be on when the switch is open and off when the switch is closed.
Old 07-06-2009, 10:10 AM   #4
Hi thanks for the replys, had the switch wired red to both the Live terminals and black to both the Negative, have now changed the black wires over to opposite Negatives but the neon still stays on if the switch is in the off or on position. Any other suggestions please.
Andy
Old 07-06-2009, 11:31 AM   #5
Code05's Avatar
Rewards Points: 1,104
please post make and model number of your switch, it will make diagnosing your problem much easier.
Code05 is offline   Reply With Quote
Old 07-06-2009, 12:21 PM   #6
It's A cheshire Electrical socket Flat Plate Satin Chrome 13 amp switched fused spur fits 25 mm box BS1363 C/w 30 mm chrome screws
(Link to there web site product )
http://www.cedecor.co.uk/cheshire_el...me/pid/5982795
Hope this is of some help
Andy
Old 07-06-2009, 01:20 PM   #7
Code05's Avatar
Andy
Hve to go,will reply later.
Old 07-06-2009, 01:43 PM   #8
Further to my previous message - found the box - has following No's thereon
BSEN 60669, BS 3676
FCS45N/SCB
Andy
Old 07-06-2009, 02:40 PM   #9
Post of a photo of the back of the switchplate. I'm curious whether the indicator light has its own set of wires (6 wires total to be hooked up) or they go into the switch (4 wires total to be hooked up).
Your link is a bit short on details. Usually they give you a schematic with wire colors, etc.
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 02:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
