Help - Electrical - DIY Chatroom Home Improvement Forum
Old 03-07-2009, 10:55 AM   #1
Help
I changed out all the light switches and outlets/plugs in my house but now the ones that use to control a light with a switch aren't working did I install the wrong switch or plug or just improper wiring i removed and reattached all wires for the same place hope someone can understand my description thanks mike
mhoy9 is offline   Reply With Quote
Old 03-07-2009, 12:39 PM   #2
Rewards Points: 150
Send a message via AIM to Bocolo
You may want to provide more information. Were they three way switches? How many wires? Are only the switches not working? It sounds like improper wiring. You have many knowledgeable guys in here that will be able to help out. Pics would also be very helpful. Did you connect all your white wires to all your silver colored screws and all black wires to all your copper colored screws? Do you have power in some or none at all? Thanks.
One Pound of Knowledge Requires Ten Pounds of Common Sense In Order To Be Useful
Bocolo is offline   Reply With Quote
Old 03-07-2009, 05:15 PM   #3
Remodeling Contractor
if you are talking about that the switch no longer controls an outlet... this is a split feed to the outlet. On the hot side (copper colored) you need to break the copper tab that connects the plate under these screws. This allows the one outlet of the duplex to be hot all the time and the other to be switched.
Old 03-07-2009, 11:10 PM   #4
You didn't describe anything
220/221 is offline   Reply With Quote
