HELP!! 3 Way Wiring For Lights With 3 Zones - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2013, 04:06 PM   #1
HELP!! 3 way wiring for lights with 3 zones
Ok here is my scenario! 11 lights on one circuit split into 3 zones.
Zone 1 has power coming in and has a 3 way dimmer controlling 3 lights.
Zone 2 has power coming from the last light in Zone 1 to a 3 way dimmer controlling 4 lights.
Zone 3 has power coming from the last light in Zone 2, also to a 3 way dimmer controlling 4 lights.
All 11 lights are on a 15amp breaker, lights are 15w par30 led's.
I would like all 11 lights to turn on from Dimmer Switch in zone 1, but each dimmer switch will be controlling their own respective zones.
Will the way i wired it work? if not please advise.
Thank you.
BigSi is offline   Reply With Quote
Old 01-28-2013, 04:19 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
Dimmer 1 will control all the lights to what ever level you set, then the next dimer will never be any brighter than the first dimmer setting, and the last dimmer will never be any brighter than the second dimmer setting.
I would look into a self contained lighting control.
Old 01-28-2013, 07:08 PM   #3
joed's Avatar
Rewards Points: 13,358
Where is the second three way dimmer?
Old 01-28-2013, 07:25 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,512
Yes and No !
With the current configuration,
the first dimmer will act as the master,
So its level will determine the overall
level of zones 2 & 3.
To get to work as you would like
ie individual control of three zones
you would have to reconfigure the wiring.
Zones 2 & 3 would need a power feed
that originates from before dimmer 1,
but after switch 1.
dmxtothemax is offline   Reply With Quote
Old 01-28-2013, 07:57 PM   #5
dmxtothemax:
What suggestions do you have to rewire this to work, a friend said that adding a standard switch at the beginning might help?
Old 01-28-2013, 08:03 PM   #6
It controls zone 2.
A more simplified scenario would be the following:
3 lights in a row with each light controlled by its own dimmer switch, a switch at the beginning is able to turn them all on or off.
Old 01-28-2013, 08:31 PM   #7
Rewards Points: 506
Send a message via AIM to theatretch85
I would look into the Leviton DHC (Decora Home Controls) or the Lutron programmable dimmers for this setup. Each dimmer would then get its own power input and you can get special controllers that can control all the lights in one central location (while still having remote control at the 3-way switch). I installed several of the Leviton DHC dimmers and 7 Scene controllers in my basement/wet bar and I love the setup! I have one scene setup for all lights on full for when I want it lit up in the basement.
Works great and I'd highly recommend it!
theatretch85 is offline   Reply With Quote
Old 01-28-2013, 10:10 PM   #8
Originally Posted by BigSi View Post
dmxtothemax:
Take a cable off the switched side of the first switch
(before the dimmer) run this wire as a hot to switch/dimmer2.
loop then take off as hot to switch/dimmer 3.
You might need an neutral and earth at each switch
to keep up to code.
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 09:43 AM
Old wiring to new wiring Acworld34 Electrical 3 07-11-2011 10:00 AM
Concrobium and knob and tube wiring WillK Electrical 13 02-28-2011 12:17 PM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
