Help With 3 Pairs Of 3 Way Switches In Series - Electrical - DIY Chatroom Home Improvement Forum
Old 10-17-2012, 10:38 PM   #1
help with 3 pairs of 3 way switches in series
Hello,
I'm finishing my basement. I'd like to know if this is possible. Three lights controlled by three pairs of 3-way switches. 1st light in gym, 2nd light in office, 3rd light in hallway. I'd like to be able to control each light in each area at the entry and exit points.
From the electrical panel 14/2 cable to first single gang 3-way switch that will be at front of gym. 14/3 from first single gang to double gang that will be at end of gym and front of office area. This double gang has two 3-way switches, one for gym, one for office. Then a second double gang with two 3-way switches, one for office and one for hallway. Then finally a single gang with a 3-way switch at end of hallway.
For extra points! Actually. I'd like to have two lights in the gym area.
I'd like someone to explain if and how this can be done.
Thanks in advance!
Steve
Steve247 is offline   Reply With Quote
Old 10-17-2012, 11:22 PM   #2
joed's Avatar
Rewards Points: 12,000
Not going to work.
Unless you run four wire cable from the first box the second box you can not put the second three way there. You do not have unswitched power for the second three way. The first three way will control the second and third three way. And the second three way will control third three way.
Tags
3-way switch , multiple 3-ways same box
Bath Exhaust Fan Timer Switch--2 Switches in Series hammerlane Electrical 5 01-07-2012 07:09 PM
Relay Switches for fan in ADP R series Air Handler Goode HVAC 1 01-06-2012 05:07 PM
Outlets and switches in series or parallel? Tetranitrate Electrical 4 07-11-2011 03:35 PM
Two switches in series for boiler WaldenL Electrical 9 01-04-2011 04:01 PM
light switches wired in series -- why? magnolia Electrical 2 05-11-2008 12:16 PM
