Help - Electrical - DIY Chatroom Home Improvement Forum
Old 07-18-2008, 11:44 PM   #1
help
i cant figure out how to wire my pool pump that is listed 115/230 i switched the plug on the pump to 115 but when i hook up the plug all the motor does is hum and get hot.....how do i wire this thing so i dont burn up the pump
Last edited by kirk1234; 07-19-2008 at 12:04 AM. Reason: to get more attention i hope
kirk1234 is offline   Reply With Quote
Old 07-19-2008, 01:02 AM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Lets see if I understand.
You cut the 230 volt plug off the pumps power cord and replaced it with a 115 volt plug?
Did you also run the branch circuit wiring to the pump or is it existing?
Old 07-19-2008, 11:14 AM   #3
Rewards Points: 58
I think he meant he switched the "plug"?????? from 230 to 115. Maybe a jumper or something to change the voltage. Since he says it hums and gets hot, I would think he has already fried the motor.
Kirk....Please look at the wiring diagram on the motor nameplate
