-   -   help (http://www.diychatroom.com/f18/help-23894/)
kirk1234 07-18-2008 10:44 PM
help
i cant figure out how to wire my pool pump that is listed 115/230 i switched the plug on the pump to 115 but when i hook up the plug all the motor does is hum and get hot.....how do i wire this thing so i dont burn up the pump
Stubbie 07-19-2008 12:02 AM
Lets see if I understand.
You cut the 230 volt plug off the pumps power cord and replaced it with a 115 volt plug?
Did you also run the branch circuit wiring to the pump or is it existing?
J. V. 07-19-2008 10:14 AM
I think he meant he switched the "plug"?????? from 230 to 115. Maybe a jumper or something to change the voltage. Since he says it hums and gets hot, I would think he has already fried the motor.
Kirk....Please look at the wiring diagram on the motor nameplate
