Help With 1940s Switched Bath Wall Light Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 06-01-2013, 12:40 PM   #1
Rewards Points: 248
Help with 1940s switched bath wall light fixture
I would like to replace the bathroom wall light fixture, which has a two-prong plug outlet, and a central socket for the bulb which has an on/off chain pull. I want to replace it with a simple light fixture (no two-prong outlet and no switch) and have it be controlled by the wall switch only.
I'm including a couple of pictures. Two brown wires go the central bulb socket where the chain pull is located. White and black wires go to the 2-prong plug outlet. There's no ground wire.
We will rewire this bathroom someday but for now, that is not an option. What happens to each of the wires: Black, White, and the two browns? What I think should happen is that the white and black each get capped with a wire nut so they do nothing, and the brown wires go to the hot and neutral on the new fixture. Is that right?
Help with 1940s switched bath wall light fixture-bathlightfixture.jpg   Help with 1940s switched bath wall light fixture-bathlightfixture1.jpg
diy888 is offline   Reply With Quote
Old 06-01-2013, 01:44 PM   #2
Resi EC
Rewards Points: 252
what are they tied to in the box? as those will be the wires used for the new fixture, not the wires connected to the fixture in your photo
Gac66610 is offline   Reply With Quote
Old 06-01-2013, 04:05 PM   #3
MarginallyQualified
Rewards Points: 2,464
Does the wall switch control the light now? Or the chain pull?
We'll get to that next...
lets focus on what is controlled by a wall switch (or not).
Old 06-03-2013, 05:07 PM   #4
Rewards Points: 248
Thanks for the helpful troubleshooting questions, which showed me that I was making a false assumption. I assumed there was a three-way switch (on/off at light fixture or on/off at wall switch) but everything is controlled by the wall switch. I just got rid of the brown wires and hooked up the remaining white and black to the new fixture.
using light fixture to power 40" lcd tv? hoszor Electrical 3 07-21-2011 10:20 AM
HELP! Wiring 2 switches with new light fixture michugana Electrical 7 04-10-2011 06:49 PM
New Light Fixture won't turn off Aubullion Electrical 4 02-22-2011 12:23 AM
Electrical bathroom vanity light fixture HEMMY1244 Electrical 4 09-29-2010 07:40 PM
move light fixture from celing to wall diyintn Electrical 8 09-10-2010 03:58 PM
