Help - Electrical - DIY Chatroom Home Improvement Forum
Old 04-01-2013, 09:28 PM   #1
ericmunyon12345's Avatar
Help
I'm running a 20 amp line for a few receptacles, but at the end of all of them I'd like to junction to a 14 ga. line that feeds an outdoor light. It will have a 15 amp gfci protection, but I'd like to add line protection for the drop in wire gauge (14 ga on 20 amp). I saw years ago in a home a screw in fuse socket that was part of the cover of a handy box. In other words, at the junction i could install over current protection for 15 amps via a fuse.
I can't find this online though. Anyone have either a suggestion or a link to what I'm looking for (ideally at depot/lowes)?
ericmunyon12345 is offline   Reply With Quote
Old 04-01-2013, 09:31 PM   #2
Electrical Contractor
kbsparky's Avatar
It IS possible, but I would not recommend doing this. Just use a #12 wire for that tail end of the circuit to the fixture. Cheaper than buying that fuse holder/cover.
I believe you are looking for an SRU cover.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
ericmunyon12345 (04-01-2013)
Old 04-01-2013, 09:33 PM   #3
Electrical Enthusiast
Rewards Points: 504
I have seen what you're describing in the electrical department at lowes. I don't know if it's legal to set it up that way though.
Kyle_in_rure is offline   Reply With Quote
Old 04-01-2013, 09:45 PM   #4
Access to the wire is the issue; I'll look into running 12, but it may be more of the pain than the $10. As the only draw is one light fixture, I'm sure some would just junction and call it good.
Cost aside, will that cover with a 15 amp fuse work to provide appropriate protection for this 15 chunk of line?
