#1 |
Help!
I am replacing a light in my hallway that is about driving me nuts. Normally you attach black to black, white to white, etc. but when you do this the light does not shut off. Installed new light switch thinging that was it but still the same! Any suggestions?
#2 |
Licensed electrician
Help!
Did the old fixture work correctly? Did you connect to the same wires as the old fixture?
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. |
#3 |
Help!
yes the old fixtures worked fine. i am updating them. i would have attached as previous one but new light has two black and two white, only wires attached in old one was the black wires. the white were shoved up in ceiling.
#4 | |
Help!Quote:
#5 |
Help!
if that is the case (they switched the neutral) what do i do
#6 |
Licensed Electrical Cont.
Help!
Unless the house is VERY old I seriously doubt it.
mommadot, please post a picture of the ceiling box.
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
#7 | |
Help!Quote:
#8 | |
Help!Quote:
#9 |
Help!
If the switch loop emanates from the light fixture then you have
used the wrong wires ! How many wires are there total ! And what color? |
| Display Modes | |
