Hello From Va Mobile Home Light Switch Issues - Electrical - DIY Chatroom Home Improvement Forum
Old 09-29-2009, 03:40 PM   #1
hello from va Mobile home light switch issues
I am the owner of a 1990 mobile home and want to change my light switches. I dont have alot of electrical experience but I have changed light switches before. The switches in my bathrooms are self contained and have six wires that lay in the switch. Is there a way to change these to the standard light switch?
mjadec01 is offline   Reply With Quote
Old 10-10-2009, 12:22 AM   #2
Registered User
Rewards Points: 4,912
Welcome to the forum! Greetings.
Be safe, Gary
Old 10-13-2009, 09:41 PM   #3
I just had the same issue. the new switch should have 3 wires if it is a single pole switch. my new switch had two black wires and a green one(the green being the ground wire). from the wall, i had two sets of wires. in each set was a white, a black, and a bare wire. i connected the each black wire to a white wire. the green wire to the bare wire and then connected the two black wires from the wall together. let me know how it works for you.
and if you know the answer to this one, i didn't buy a self-containing outlet. how would i get it to stay in the wall securely?
rmcgary_05 is offline   Reply With Quote
Old 10-13-2009, 09:52 PM   #4
300zx's Avatar
Post
Why open another thread ???
Why open another thread ??? ON THE SAME 2 GANG SWITCH BOX???
Here is the other Thread mobile home light switches
300zx is offline   Reply With Quote
Old 10-13-2009, 10:24 PM   #5
new to the whole forum thing. my bad. no need for stroke
Replacing light switch in series wired home - help! kellykate Electrical 6 04-16-2009 07:37 PM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
Tracing light switch to an outlet allanet Electrical 13 04-03-2009 09:44 AM
Home interior dimmer switch waltersawicki Electrical 2 10-21-2008 07:51 AM
no power going to the light switch baseballfan Electrical 18 09-08-2008 06:35 PM
