Hello, New Member. New House, Wiring Mess! - Electrical - DIY Chatroom Home Improvement Forum
Old 10-12-2012, 04:28 PM   #1
Hello, new member. New house, wiring mess!
Hello, my wife and I bought our first home. We are finding that there are some things needing to be upgraded. I was crawling through our attic inspecting a spot where I'd like to install a recessed light. Our house is wired with the older cloth covered romex and about half is wired with the newer romex. While in the attic, I found some interesting things. A few splices and a stray hot piece of romex. I will post pics of what I found. One splice in particular seemed very bad.
Attachment 58746
These wires run down to a switch, out trough the soffit to an outside ceiling fan, and then power out to the rest of the circuit. Trouble is, there is no slack on any of it. Also, it is in the narrowest part of the attic where the roof ends. I know splices need to be in a box and accessible.
Attachment 58747
Different view.
I found this, hot, so I terminated into a handy box and attached to a roof truss
Attachment 58748
Attachment 58749
Any advice on fixing that terrible hack splice job would be greatly appreciated. I can't afford an electrician right now but am very handy.
kvantassel is offline   Reply With Quote
Old 10-12-2012, 04:29 PM   #2
Didn't mean to post twice
Old 10-12-2012, 05:33 PM   #3
Rewards Points: 332
Attachment 58746
Attachment 58747
Different view.
Attachment 58748
Attachment 58749
You're on the right track. J-Boxes. Just make sure you size them properly and don't over fill them. Also, if you use metal boxes, ground the boxes when possible.
sgip2000 is offline   Reply With Quote
Old 10-12-2012, 05:56 PM   #4
Thanks! By ground the box do you mean to pig tail a ground wire from the connections to the box?
Old 10-12-2012, 06:07 PM   #5
Oso954's Avatar
Rewards Points: 736
You say you can not afford an electrician.
Ask yourself if you can afford not having one.
You did a good job on spotting and recognizing 2 examples of hack work.
How many have you either not spotted or recognized ???
It's not what you have found that should make you worry. It is the ones that you have not found.
Oso954 is online now   Reply With Quote
Old 10-12-2012, 06:25 PM   #6
Rewards Points: 332
Yes, a ground screw in the box to all the other ground wires.
Oven wiring, old house. Pluf2 Appliances 5 02-18-2012 10:03 PM
Help with wiring issues on a newly purchased house ThatGuy Electrical 13 01-17-2012 11:51 AM
House wiring diagram help oxicottin Electrical 13 09-20-2010 06:25 PM
trying to get educated about house wiring ChrisJJ Electrical 7 08-08-2010 03:23 PM
Charred / melted wall receptacle, AL wiring in house creamaster Electrical 17 12-04-2009 05:47 PM
