-   -   Hello, new member. New house, wiring mess! (http://www.diychatroom.com/f18/hello-new-member-new-house-wiring-mess-159860/)
kvantassel 10-12-2012 03:28 PM
Hello, my wife and I bought our first home. We are finding that there are some things needing to be upgraded. I was crawling through our attic inspecting a spot where I'd like to install a recessed light. Our house is wired with the older cloth covered romex and about half is wired with the newer romex. While in the attic, I found some interesting things. A few splices and a stray hot piece of romex. I will post pics of what I found. One splice in particular seemed very bad.
Attachment 58746
These wires run down to a switch, out trough the soffit to an outside ceiling fan, and then power out to the rest of the circuit. Trouble is, there is no slack on any of it. Also, it is in the narrowest part of the attic where the roof ends. I know splices need to be in a box and accessible.
Attachment 58747
Different view.
I found this, hot, so I terminated into a handy box and attached to a roof truss
Attachment 58748
Attachment 58749
Any advice on fixing that terrible hack splice job would be greatly appreciated. I can't afford an electrician right now but am very handy.
kvantassel 10-12-2012 03:29 PM
Didn't mean to post twice
sgip2000 10-12-2012 04:33 PM
Attachment 58746
Attachment 58747
Different view.
Attachment 58748
Attachment 58749
You're on the right track. J-Boxes. Just make sure you size them properly and don't over fill them. Also, if you use metal boxes, ground the boxes when possible.
kvantassel 10-12-2012 04:56 PM
Thanks! By ground the box do you mean to pig tail a ground wire from the connections to the box?
Oso954 10-12-2012 05:07 PM
You say you can not afford an electrician.
Ask yourself if you can afford not having one.
You did a good job on spotting and recognizing 2 examples of hack work.
How many have you either not spotted or recognized ???
It's not what you have found that should make you worry. It is the ones that you have not found.
sgip2000 10-12-2012 05:25 PM
Yes, a ground screw in the box to all the other ground wires.
