Heil 5000 I Think - Electrical - DIY Chatroom Home Improvement Forum
Old 10-03-2010, 09:50 AM   #1
Heil 5000 I think
My funace on cover has 5000 on it so kinda assuming that it must be a heil. Anyway the fan keeps running and the heat will not come on. When turning heat on the thermastat it says its on and can here the thermastat click
Kspeelman is offline   Reply With Quote
Old 10-03-2010, 10:41 AM   #2
Could there be a reset switch?
Old 10-03-2010, 08:35 PM   #3
is this a electric furnace or a gas? looking for a reset switch or the circuit breakers at the panel or the unit itself disc. Or maybe fuses may have been used. Check to see any are open. if gas, the igniter maybe at fault thats the weird thing right above the gas burner that gets red hot when the furnace wants to fire up the main burners. You can tell real easy if its bad , look at it real close and it should be a continuous loop w/ no breaks if its broken the voltage willnot go thru and get hot and ignite the gas when the gas valve opens, theres a thermo couple that tells the valve the gas is being used when it gets hot and willnot let the gas valve open if it dosnt.
Kirky is offline   Reply With Quote
Old 10-04-2010, 05:25 AM   #4
Its gas
Old 10-04-2010, 06:39 AM   #5
sounds like the same problem i had with a gas furnace some years ago. I cant remember the exact details, but the HVAC guy was able to fix it by replacing one of the circuit boards in the furnace.
sorry i cant be more specific than that.
1910NE is offline   Reply With Quote
Old 10-04-2010, 06:59 AM   #6
How bout bad thermostat?
Old 10-04-2010, 07:16 AM   #7
Electrical Contractor
kbsparky's Avatar
Some units will do that if the control transformer quits. Check for 24 V on the internal transformer, or check to ensure a control fuse isn't blown.
-KB
Old 10-04-2010, 07:37 AM   #8
I=E/R
a7ecorsair's Avatar
A bad thermostat is possible, but first, why is the fan running? Do you have the fan set to run all the time? In most gas furnaces the fan isn't turned on until the stack temperature warms up.
Does the furnace have a standing pilot or is direct spark ignition?
I had a Lux thermostat go bad several years ago. It was programmable model and I could hear the relay pick inside the thermostat but the furnace didn't light. Hooked up the old thermostat that I still had and the furnace fired right up. That's why I keep stuff, never know when you may need it. Of course my wife doesn't see it that way
a7ecorsair is offline   Reply With Quote
Heil 5000 blue1952 HVAC 4 08-17-2010 08:47 AM
heil 5000 furance harley75 HVAC 17 01-16-2009 08:08 PM
Heil 5000 AC robtspcr HVAC 1 02-10-2008 03:04 PM
The Heil 5000 Air Conditioner circlecity4u HVAC 1 05-03-2006 09:54 PM
HEIL 5000 Furnace Problem moore70 HVAC 5 03-26-2006 07:59 PM
