Old 04-22-2010, 01:47 PM   #1
height of wall switches?
Is there code for height of wall switches?
I want to install whole house fan control next to my thermostat which is a little higher than a light switch, keep it out of way of kids also.
DIYGST is offline   Reply With Quote
Old 04-22-2010, 02:03 PM   #2
Electrician
No code for heights of switches, sometimes it is beneficial to keep them higher like in your case. When you install a gas funrnace with a disconnect its benefical to keep them higher for little kids don't play with them.
darren is offline   Reply With Quote
Old 04-22-2010, 02:09 PM   #3
Military Mom of 4
Snav's Avatar
I've installed all my switches and even some plugs at 4' - it's a comfortable reach, easy measure and also ensures clearance above any future furniture, cabinets, tables and so on. It's also well out of reach of little ones. And, if you're standard when you do your work, it makes cut-outs in drywall easier to measure for.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Framing an unfinished basement captainobvious Building & Construction 7 10-16-2009 10:53 AM
Can't tell what to do with this wall, load bearing?? fox_forma Building & Construction 22 09-26-2009 06:31 PM
correct wall height Mudball Building & Construction 6 08-22-2009 07:25 PM
building a wall against an exterior wall Mike L General Discussion 2 08-20-2009 03:50 PM
Temporary wall support question discojv Building & Construction 7 01-25-2009 08:23 PM
