Height Requirement For Boiler Shutoff Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 10-13-2010, 12:24 AM   #1
Just call me Andrew
Rewards Points: 1,020
Height requirement for boiler shutoff switch
I am putting in an emergency boiler shutoff at the top of my basement stairs. Is there any code requirement or suggested height for this switch? Or just high enough where it is reachable by a short person, yet not in the way where you may accidentally shut it off?
Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 10-13-2010, 07:06 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
I use 60". I have never seen an actual height requirement though.
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
secutanudu (10-13-2010)
Old 10-13-2010, 08:28 AM   #3
Rewards Points: 6,652
High enough that it will not be bumped into. Place it at the highest point you can reach by extending your arm. If placing lower, you may want to put a cover on it, that it would not be turned off "accidentally".
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 03:17 AM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 09:00 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
