Height Of Receptacles? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-12-2007, 11:33 PM   #16
Rewards Points: 5,336
Originally Posted by sandyman720 View Post
I have a new addition with a powder room. I was told I need an exhaust fan.
I was thinking about mounting one on the wall since I have no room to run a vent since I have 2x4 ceiling joists and the ceiling buts up to a room above.
Is there any restriction on where the exhaust fan can be mounted?
How much deeper will the wall studs be? Another option is to put in one of those fans where the motor is at the exhaust point. This way you only need to install a vent grill in the bath.
Ron
Old 09-13-2007, 12:03 AM   #17
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
You're not outdated till someone asks your wife if she has any antiques and she replies "just my husband".
As for receptacle box height, I mark all studs 16" top of box, and x the side I want, then I mount, this lets me see any location corrections before the box goes on.
Stubbie
Old 09-13-2007, 07:55 AM   #18
Rewards Points: 152
Thanks guys.
In new construction when running a wire to a light that will be outside (like 2 lantern style lights on both sides outside of a sliding glass door); should a work box be used?
Siding will be on the exterior.
How do you normally do this?
sandyman720 is offline   Reply With Quote
Old 09-13-2007, 03:37 PM   #19
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
I don't know what a "work box" is but you do need some sort of box.
If it is vinyl I use these:
Speedy Petey is online now   Reply With Quote
Old 09-13-2007, 04:05 PM   #20
Licensed Pro
You can get those for Hardi siding also. I have started just leaving cable stuck out of the wall and adding the siding box/block after the siding is up.
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
gfci receptacles rjr Electrical 2 05-02-2007 08:16 PM
raising ceiling height during remodel marks Building & Construction 1 10-04-2006 02:58 PM
Joining laminate floors of different height. flyingmachine Flooring 5 09-13-2006 09:59 PM
Number of receptacles and size of wires KUIPORNG Electrical 5 06-28-2006 02:21 PM
