Height Of Meter Box - Electrical - DIY Chatroom Home Improvement Forum
Old 05-22-2011, 09:52 PM   #1
Rewards Points: 199
Height of meter box
I understand that a meter box should be between 4' and 6' from grade and ideally 5'.
Is that measured from the bottom of the box, the top of the box, or the center of the meter ?
My real question, however, is:
If the meter box is mounted on the wall of a house that has a porch and the porch roof is over the meter, can the floor of the porch be considered grade ?
In other words, when the meter reader comes up on the porch and the meter is then at his eye level, is that ok ?
(The floor of my porch is 4' above grade, and if the meter was mounted 5' above grade, the bottom of the service panel would have to be about at floor level to be opposite the meter box)
Thanks,
Arky
Arky217 is offline   Reply With Quote
Old 05-22-2011, 09:56 PM   #2
Licensed electrician
Rewards Points: 1,296
You need to check to see if your power company will allow the meter over the porch.
My power compnay uses the height of the center of the glass.
Old 05-23-2011, 09:26 AM   #3
Rewards Points: 3,130
Is this new construction? In any case, the POCO has the final say on where the meter box goes. And sometimes they will approve something that isn't strictly to code. Mine is a good example. When I built my log house, I never got temporary power - I laid the conduit myself (125 feet) and had the POCO pull the permanent conductors. The meter and breaker panel were temporary and mounted on a post at the corner of the house. When it was time for the permanent installation, they at first said I couldn't put it where I wanted to because it would be too close to a window. But after telling me where it had to go, they realized the distance would be far enough that they'd have to pull new, larger conductors. They decided where I originally wanted to put it would be OK after all.
Old 05-23-2011, 10:05 AM   #4
Rewards Points: 324
general rule is top breaker must be no more than 74"from what ever you call grade.as in if mounted above a deck,from where you stand reach up,you should be able to turn off top breaker.
oleguy74 is online now   Reply With Quote
Old 05-23-2011, 11:56 AM   #5
I ask the impossible!
Rewards Points: 644
Oh yeah, I had meant to post a response but it got lost in a loading error when I clicked submit.
Let me re-emphasize the importance of checking with the power company on this. In the process of planning out my service entrance move, I read my own POCO's requirements as well as several others I read for reference. It seems typical that the requirement will be from ground to the center of the meter face. However, different power companies have different height requirements. I've read some that specify a height and I've read others that require it to be within a range.
While you're asking, you can check about the porch.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
New service Help (Meter can/ service mast Conduit help) cwolford Electrical 13 03-26-2011 08:55 PM
Possible Defective or Incorrect Electrical Meter? MorganB Electrical 10 01-18-2011 10:51 AM
Is My Electric Meter Correct: Conclusion. fcfcfc Electrical 0 10-03-2010 07:00 PM
Tiny elbows on meter? pcampbell HVAC 24 10-06-2009 10:54 AM
Water meter aggravations Ultrarunner2017 Plumbing 8 03-21-2009 07:53 AM
