Height of a ceiling fan with a trey ceiling?
I've decided to get a LCD projector for my living room. Due to a chair rail/wainscoating, I forced to put the 60" tall screen an inch from the top of the 8' wall. There is a trey ceiling in the room and the ceiling fan hung on a 24" rod of the trey ceiling. The too low fan will interfere with the projectors image. I was thinking of just removing the rod of the ceiling fan and mounting it directly to the trey ceiling so it's out of the way from the projector. Then get some excessively long 24" pull handles to maintain easy access to the lights and fan speeds.
Would that greatly hinder performance of a ceiling fan? |
If the fan was designed so it can be mounted directly on the ceiling, there should be no issues mounting it that way, as long as the blades clear the edges of the tray, and the ceiling is flat (not angled). If the ceiling is angled, or the fan wasn't designed for direct mounting, you can buy a shorter rod at pretty much any home center, or you can shorten the existing rod yourself. As for the controls, I'd recommend buying a remote rather than dangling cords down.
With the remote, I just assume it was part of the fan itself, which mine didn't come with. Can you add in a remote control circuit to it? Eh, maybe I'll just buy a cheapo wally world fan w/remote... |
Also, you can install a fanspeed control on the wall to avoid the hanging pull chains. |
ceiling fan height from ceiling
Just a note. The farther the ceiling fan is from the ceiling, the better circulation and air flow you will get. If this is in a bedroom, I would think that would be important.
Thanks Bye :) |
| All times are GMT -4. The time now is 07:46 AM. |
