Heeellllppppp Me And My Sister Change Light Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 06-11-2010, 05:31 PM   #1
heeellllppppp me and my sister change light fixture
is someone avaliable to help me and my sister change light fixture!!.. everything just going wrong!!
kirsty is offline   Reply With Quote
Old 06-11-2010, 05:44 PM   #2
Turn off power
Undo screws/nuts etc holding old fixture in place
Undo black/white/ground wires from old fixture
Attach black/white/ground to new fixture
Secure new fixture w/screws etc to hold it in place
Old 06-11-2010, 06:17 PM   #3
DIY staff
Rewards Points: 7,174
What is going wrong? Need a picture of the old and the new.
Old 06-11-2010, 07:12 PM   #4
Rewards Points: 1,910
After the power is off at the breaker box (not the light switch) and you take off the cover plate don't disconnect anything. Unless you are absolutely sure you have the right circuit shut off check with a voltmeter to make sure all the wires in the box are truly dead.
Second thing to do for an inexperienced person is to draw every wire in the box and what it's hooked to. Your going to need to put it back together exactly the same and most beginners have trouble remembering what connected to what. You can even use little pieces of tape to label each wire if that will help.
After that its easy. Just hook the same color wires from the new light to where the same colors of the old light were attached.
Old 06-11-2010, 09:50 PM   #5
Take lots of photo's! After you have turned off the circuit breaker, take a photo each time that you remove something.
Generally, there are two screws holding the fixture up. Sometimes these screws are driven with a screw-driver, sometimes there will be a 'nut' that is turned off with a nut driver. In both cases, turn them anti-clockwise to undo them.
When the fixture drops away from the ceiling/wall, the wires can be accessed in the electrical box.
What I do, is cut the wires from the old fixture, about an inch from the wire nuts. This gets it out of the way. And yet lets you know what wires were connected to what.
Next, if there's a green or bare copper wire connect this to the green wire on the new fixture with a wire nut. Or if possible, connect the new green wire to the terminal screw.
Next, connect the new white wire in place of the old one that was cut off.
Finally, connect the black wire in place of the black one that was cut off.
Tuck all the wires into the box and screw the fixture into place.
Then, turn the panel breaker back on, and try out your new light!
Old 06-11-2010, 09:52 PM   #6
Rewards Points: 512
If you get it taken apart and have any questions at all, please come back and ask one of these kind gentlemen. If you don't get everything put back together properly, you could start a fire in your wall/ceiling. I don't mean to scare you, but it's better to be safe than sorry.
Barb
gma2rjc is online now   Reply With Quote
Help with Light Fixture - Braided Romex, possible Arc, is wiring safe? cntnick Electrical 5 03-17-2010 11:22 AM
Relocating a light fixture Eclipse99 Electrical 5 02-27-2010 10:04 PM
Light fixture: Does hot&neutral designation matter, and possible wiring anomaly. Deck Electrical 8 08-26-2009 08:08 AM
I can feel buzzing or "charged" air around a light fixture? jabrockson Electrical 10 03-26-2009 08:20 PM
find switch to control outdoor light fixture CaymanAg Electrical 1 07-10-2005 08:43 PM
