Hedge Trimmer, Cut Through The Wire (how Can I Fix It) - Electrical - DIY Chatroom Home Improvement Forum
Old 10-15-2009, 01:28 PM   #1
Hedge trimmer, cut through the wire (how can I fix it)
Ok guys, been around to my cousins new house today doing the hedges for her and took my moms hedge trimmers (my moms on hol) and about 3 mins after being told to watch I dont cut through the wire, what do I do? Got it!
I have been the the electrical shop and bought alittle plastic thing that reconects the wires (brown and blue) and put a new fuse in the plug, but still nothing.
Anyone know what I can do to fix it?
BostonsBadBoy is offline   Reply With Quote
Old 10-15-2009, 01:30 PM   #2
Electrical Contractor
Is this the wire for the trimmer?
ohmy is offline   Reply With Quote
Old 10-15-2009, 02:23 PM   #3
Safe, Most of the Time!!
brokenknee's Avatar
What wire did you cut? Is it an electric hedge trimmer? If that is the wire you cut you should replace the whole cord.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 10-15-2009, 05:57 PM   #4
Thanks for the reply.
Yes the electric cord. Is there no way I can repair the wire?
Old 10-15-2009, 06:01 PM   #5
I strip both wires, twist them back together/solder them then tape the up so they can't short out
There may be an internal part that fried when it shorted
Old 10-15-2009, 06:41 PM   #6
300zx's Avatar
Post
Is this rec on a GFCI somwhere take something you know works and plug it in and if you have no power look for a gfci somewhere
300zx is offline   Reply With Quote
Old 10-15-2009, 06:46 PM   #7
" Euro " electrician
frenchelectrican's Avatar
Just want to head up the OP is from UK due the two key word gaveaway is fused plug and colour codes
And with UK they should have RCD on outdoor circuit and it will be in the distubaiton centre { breaker box }
Merci.
Marc
Old 10-15-2009, 06:48 PM   #8
300zx's Avatar
thanks
Merci.
Marc
Thank you didn't catch that thank you.
Old 10-15-2009, 07:07 PM   #9
joed's Avatar
Rewards Points: 13,696
If it is the extension cord put a plug on both and have two short cords instead of one long one.
If it is the trimmer cord can you put a plug on the cut off end and have shorter cord?
Old 10-15-2009, 07:11 PM   #10
brokenknee's Avatar
Merci.
Marc
And here I though he was from Boston because of his/her user-name.
Old 10-15-2009, 07:22 PM   #11
OP's IP does track to the UK
Old 10-15-2009, 08:48 PM   #12
brokenknee's Avatar
The little trickster was trying to make us think he was one of us on the "good side" of the pond.
Old 10-15-2009, 08:58 PM   #13
I know it may be little off topic but here is the city of Boston UK
http://www.mapquest.co.uk/mq/maps/ma...City=Boston%20
Just click on that it will show up
Merci.
Marc
Old 10-16-2009, 06:29 AM   #14
Memories
QUICK STORY
WOW, you brought back memories When I was a kid my dad cut the hedges by hand with shears then he bought new electric shears and let me cut the hedges and kept saying don't cut the cord.
Well you know I cut it about the same time as you, man he was hot.
I think he just twisted the wires together and used cloth black tape.
It's a miracle nobody was killed. Repair the cords like #9 said.
SULTINI is offline   Reply With Quote
Adding a wall switch to a pull chain fixture abacuslearns Electrical 17 12-20-2011 06:02 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 09:16 AM
Red wire is HOT genner Electrical 15 02-22-2009 08:14 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
