Old 01-10-2013, 03:02 PM   #1
Heavy Chandelier Foyer Install?
Hello All,
I am planning on replacing a approx. 50lb chandelier in a two story foyer with a
130 lb chandelier.The home is newer construction 2x4 "truss" system in attic space. I have purchased the Westinghouse Hercules j-box system rated to handle up to 800lbs. Fixtures to replace the existing one since it is not strong enough.I have also purchased a worm gear manual winch 2000lb rating which I plan to use to lower the existing fixture and "raise" the replacement. I have attic access from above which is where I plan to mount the winch temporarily to get the job done , a 14' step ladder (ceiling height is 17'6")will give me access to the ceiling for the wiring/j-box connections...I plan to cut a small access hole alongside the existing j-box hole in the drywall to allow the hook /cable to drop down to first floor. Anyone here have any advice from experiences doing this?
ArcsX9976 is offline   Reply With Quote
Old 01-10-2013, 04:31 PM   #2
Ok you seem to have it all figured out but here are a few pointers .....don't do it alone.....do you know if your circuit can handle the new power demand of the fixture without overheating .........I did something similar before it took 4 guys and 1/2 day to set it up plus anextra circuit for the fixture
RAUL HIDALGO is offline   Reply With Quote
Old 01-10-2013, 07:53 PM   #3
Thanks for pointing that out Raul...I will have to check the circuit and see what else is on it(if anything)...I would imagine that it's on a 15amp breaker..max wattage recommended per bulb is 25 watts...there are 25 sockets on this fixture...I'll probably use 15w or 20w max...as far as help I will get some heads over to assist in the attic and on the ground.
Old 01-11-2013, 08:09 PM   #4
Maybe rent some scaffolding for the day. Its probably an expensive fixture so you don't want a mishap. I just feel safer on scaffolding than a ladder. So much so I bought three stages a few years ago. I don't use it often but when I do I am glad I have it.
curiousB is offline   Reply With Quote
Old 01-11-2013, 08:22 PM   #5
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
25 x 25w = 625w / 120 = 5.21amp draw for the chandelier.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 01-12-2013, 07:33 AM   #6
Master Electrician
Don't forget that a 14 foot step is not 14 feet tall when erected. I recently did a much lighter fixture on the same height ceiling from my 16 foot stepladder and I'm not sure I would have been happy doing it on a fourteen.
Mark
Licensed Master Electrician
Commonwealth of Virginia
busman is offline   Reply With Quote
Old 01-12-2013, 08:06 AM   #7
Nest Home Improvement
NestHI's Avatar
I would have few sets of hands to help you out. I do like the scaffold suggestion...much more stable than ladders!
NestHI is offline   Reply With Quote
Old 01-13-2013, 08:10 PM   #8
Talking
Hi All,
Just an update...two days of sweat, lifting, creative engineering to rig up the winch about 20 trips to and from the attic and the job's done....used everything listed in the original post..VERY happy with the results, but def a job I will NEVER want to do again...thanks for all the advice on this project....I will post some pics shortly for reference for anyone looking to tackle a job like this...
Old 01-13-2013, 08:13 PM   #9
Originally Posted by ArcsX9976 View Post
Hi All,
Great....will be waiting on the pics
Old 01-13-2013, 09:25 PM   #10
photos of the various stages of the project.....mounted winch to sistered up 4x4x8 and 2x4 mounted in attic across 4 joists, access hole next to junction box, cable/hook lowered and raised through there....
Heavy Chandelier Foyer Install?-chan3.jpg   Heavy Chandelier Foyer Install?-winch.jpg   Heavy Chandelier Foyer Install?-dsc08791.jpg   Heavy Chandelier Foyer Install?-chan_2.jpg   Heavy Chandelier Foyer Install?-ladder.jpg
Old 01-13-2013, 09:55 PM   #11
I like the new fixture.
Good job on the install!
Gac66610 is offline   Reply With Quote
New deeper kitchen sink install problem jmalcolm Plumbing 3 04-27-2011 11:48 AM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 10:20 AM
New cabinets, subfloor & install height Ohming Building & Construction 10 03-02-2011 03:18 PM
Should I install interior doors before floor? pttcc Flooring 13 11-23-2010 10:02 AM
Chandelier wiring alacea Electrical 7 11-10-2010 01:32 PM
