Heating Wire To Melt Driveway Snow - Electrical - DIY Chatroom Home Improvement Forum
Old 01-23-2011, 07:42 PM   #1
Rewards Points: 33
Heating wire to melt driveway snow
I know that some companies makes systems that you install into or under the concrete and other smaller heating mats that you lay on top, but I was wondering how effective it would be to just lay some sort of heated wire along the driveway and then just plug it in when the snow starts. What I was thinking is something along the lines of an extension cord maybe a few hundred feet long that runs back and forth along the driveway and is made of a metal that resists the flow of electricity enough that it heats up to maybe 50-60 deg F or so? I imagine its going to use a fair amount of electricity but to run it just while the snow falls cant be that much and is well worth not having to shovel.
konsole is offline   Reply With Quote
Old 01-23-2011, 07:47 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
you would have, at best, a line of melted snow where your cord ran. The reason the heating elements are embedded into the paving material is so the paving material is heated which then prevents ice across the surface.
Old 01-23-2011, 08:51 PM   #3
Electrical Contractor
kbsparky's Avatar
Effective at melting snow and ice? Maybe.
Cost effective? You probably could not afford the electric bill for such a system you are proposing.
-KB
Old 01-23-2011, 09:11 PM   #4
What I think you would need is this. http://www.allwarm.com/driveway-heat.htm
Now how effective it is and what the costs are to run it I can't really say. I wanted to do this when I redid my drive way and I wish I had, once you have the system in place you can determine if you are going to use it on a case by case basis, if you don't have it, well grab a shovel. You can buy a lot of electric for ten bucks, what does it cost to have a kid shovel it?
regularguy is offline   Reply With Quote
What type wire to use from transfer switch to outdoor outlet brjl Electrical 32 11-20-2013 08:36 AM
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 06:41 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Water in Basement during snow melt gruvn Building & Construction 3 05-27-2009 08:13 AM
Snow Blower problem gregryan999 General DIY Discussions 2 02-14-2008 12:55 PM
