Heater Help & Phase? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-18-2009, 09:21 PM   #1
Rewards Points: 113
Heater help & Phase?
I'm not sure I can use my free heater. Please help with info. I was told that the heater came off a large printer. Inside the heater housing are three small fans. Each fan has the following on it: 220V-50Hz 24W, 230V-60Hz 22W, 220V-50Hz 22W, 208/230-60Hz 22W. To each fan is attached a red, black, and green wires.
Coming into the box are red, black, green, orange and brown wires. All are stranded and appear to be 14 ga.
The heater coil is attached to the brown and orange wires.
1. I assume the data on the fan indicates that it can be used on any of the listed voltages?
2. With the information given, can voltage be identified as a single phase or 3 phase?
3. I thought that the wires would have been heavier ga. to power a heater?
4. Is there any way I can determine wattage of heater?
5. If it is single phase, what type of 220 plug can I use to power coil and fans?
Captflx is offline   Reply With Quote
Old 11-18-2009, 09:29 PM   #2
1. Yes
2. Single phase
3. Appliances often have smaller than you would think wires.
4. Look closer for amother label?
5. Depends on....the wattage of the heater
220/221 is offline   Reply With Quote
Old 11-19-2009, 09:12 PM   #3
Rewards Points: 113
heater help & Phase
Thanks 220/221.
Old 11-19-2009, 11:06 PM   #4
Wire size inside fixtures have a much different ampacity rating than house hold wiring, 14 ga is good for 32 amps.
hayewe farm is offline   Reply With Quote
Replace three phase water heater with single phase keysun Electrical 12 10-24-2009 05:35 PM
Want to add a single phase Subpanel to three Phase Main meglomachinist Electrical 19 09-10-2009 04:46 PM
240 volt single phase 38 max amps heater made by patron williestyles08 Electrical 8 01-06-2009 11:20 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
