Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 03-05-2009, 11:22 AM   #1
Heater
Have a Pathon E3 heater that is 240 volts one phase max 13 amps,output 3000 watts.It has carol 10/4 wire on the heater now that is red,green,black.I want to install this heater in my garage can I use this wire from the panel and put a plug on the heater.What kind of breaker will I need and recepatcle.Thanks
dodge1972 is offline   Reply With Quote
Old 03-05-2009, 12:27 PM   #2
Remodeling Contractor
2P30 breaker. Use #10 Romex or AC or MC, not the rubber cord between the panel and the outlet.
Old 03-06-2009, 10:15 AM   #3
heater
could I use 12/2 with a double pole 20 to a receptacle and keep the rubber cord on the heater.
Old 03-06-2009, 10:27 AM   #4
yes you can. I read the size of the heater wrong. #12 on a 2P20 is all you need. Sorry.
Old 03-06-2009, 10:56 AM   #5
heater
thank you and I can use the 10/4 still on the heater
Old 03-06-2009, 12:10 PM   #6
Ok, you need a NEMA 6-20P plug and a NEMA 6-20R receptacle.
Yes, it should be ok to keep the 10/4.
This should help you find the plug you need...
http://www.frentzandsons.com/Hardwar...nfiguratio.htm
rgsgww is offline   Reply With Quote
Old 03-06-2009, 12:12 PM   #7
heater
Thanks for all the information it has been very helpful.
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 06:40 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 05:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
