-   -   Heater (http://www.diychatroom.com/f18/heater-39693/)
dodge1972 03-05-2009 11:22 AM
Heater
Have a Pathon E3 heater that is 240 volts one phase max 13 amps,output 3000 watts.It has carol 10/4 wire on the heater now that is red,green,black.I want to install this heater in my garage can I use this wire from the panel and put a plug on the heater.What kind of breaker will I need and recepatcle.Thanks
Bob Mariani 03-05-2009 12:27 PM
2P30 breaker. Use #10 Romex or AC or MC, not the rubber cord between the panel and the outlet.
dodge1972 03-06-2009 10:15 AM
heater
could I use 12/2 with a double pole 20 to a receptacle and keep the rubber cord on the heater.
Bob Mariani 03-06-2009 10:27 AM
yes you can. I read the size of the heater wrong. #12 on a 2P20 is all you need. Sorry.
dodge1972 03-06-2009 10:56 AM
heater
thank you and I can use the 10/4 still on the heater
rgsgww 03-06-2009 12:10 PM
Ok, you need a NEMA 6-20P plug and a NEMA 6-20R receptacle.
Yes, it should be ok to keep the 10/4.
This should help you find the plug you need...
http://www.frentzandsons.com/Hardwar...nfiguratio.htm
dodge1972 03-06-2009 12:12 PM
heater
Thanks for all the information it has been very helpful.
