Heated Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 12-06-2010, 06:23 AM   #1
Rewards Points: 156
Heated Ceiling fan
Hey guys I am sure you have seen the new ceiling fans with built in heaters. I am curious what type of wiring I would need to put one in my downstairs room. I currently have 12/3 wire running up to the light then it feeds the 4 outlets it has in that room. Will this be sufficient to run one of these heated fans. Thanks
ryan5068 is offline   Reply With Quote
Old 12-06-2010, 07:35 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 144
What is the wattage of the heater, and what do the instructions say about a dedicated circuit?
jbfan is online now   Reply With Quote
Old 12-06-2010, 02:42 PM   #3
Household Handyman
Rewards Points: 1,408
NO, I have not seen these anywhere. First thought hit me also: The wattage of the heater itself, regardless of the fan unit. I'm thinking some ceiling fan company has come up with a ceiling fan unit with built-in heater, and has not given any thought as to how few homes would have a dedicated circuit for any or all ceiling fans. As in your case, one circuit feeding the ceiling fan, and then four (4) duplex outlets in one room: Take the wattage of the heater, figure out the amps, add the four (4) outlets amperage into this and what would you have? Then see what size amperage breaker is feeding this circuit. Surely (maybe) the manufacturer has inserted a disclaimer with these units about the proper electrical circuit to feed these units.
Old 12-06-2010, 08:37 PM   #4
" Euro " electrician
frenchelectrican's Avatar
I have see them before couple time and they are rated at 900 or 1500 watts one of the two and I know few fan manufacters have this feature.
And I did check on fan manucater and it did mention almost 1500 watts at max setting.
so that something you will have to check little closer on this circuit otherwise IMO it will be best to run it own circuit.
Merci,
Marc
How do I get power to a new ceiling fan? sestivers Electrical 15 10-10-2016 05:16 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Normal light fixtures with suspended ceiling? Scott99999 Electrical 9 09-02-2010 05:44 PM
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 04:29 AM
Repairing ceiling Arnold General DIY Discussions 8 09-12-2008 09:13 PM
