Heat Tape Time - Electrical - DIY Chatroom Home Improvement Forum
Old 05-14-2012, 06:57 PM   #1
Heat tape time
The use of a timer for heat tape is an energy saver. Where would I obtain a timer? Where would it tie into the circuit when the heat tape is hard-wired?
I am located in Colorado where there is a lot of snow and repeated melting / freezing temperatures throughout the winter months.
Thanks for any suggestions.
retdoc100 is offline   Reply With Quote
Old 05-14-2012, 07:06 PM   #2
Rewards Points: 6,652
You do not need a timer for a heat tape. They come with a thermostatic device that attaches on the piping you are trying to protect, and will turn it on at a certain temp, then off when it gets to a certain temp. A timer defeats the purpose of having heat tape, and can fail, then you get frozen pipes. The same can be said if you lose power also anytime during Winter.
The Following User Says Thank You to gregzoll For This Useful Post:
Jeeps (05-14-2012)
Old 05-14-2012, 07:15 PM   #3
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Also doing anything you can to help prevent the pipes from freezing is recommended. I have made insulated boxes around lengths of pipes to prevent freezing and it works pretty good.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 05-14-2012, 11:55 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Which heat tape appaction are you refering to the water pipe protection or on the roof where to keep the snow melted to prevent ice damming up ?
There is few differnt proper heat tapes to use them so once you confirm that question we can able assit you more on that.
For the water pipes I genrally go with self regulated heat tape. Sure I know it cost more but it worth it than a single thermostat heat tape does it due it will keep the whole pipe at proper tempture.
Make sure you follow the manufacter instruction very carefull to get the best use of them.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
retdoc100 (05-16-2012)
Old 05-16-2012, 02:59 PM   #5
Merci,
Marc
Sorry. I was referring to the roof heat tape to prevent ice dams. The lines (with 2 separate breakers) were installed and hard wired. I had been turning them on in November and off in April. I don't know where I would connect timers to save on electricity.
Thanks the reply.
Old 05-16-2012, 04:41 PM   #6
rrolleston's Avatar
Seems temperature control would be better than a timer.
The Following User Says Thank You to rrolleston For This Useful Post:
frenchelectrican (05-17-2012)
Tags
roof heat tape , timer
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 05:38 AM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Heat Tape on Pipes and Pressure Pump msully8548 Electrical 4 08-27-2008 11:33 PM
Commercial heat tape. rforsha Electrical 3 12-04-2007 07:41 PM
