Heat Resistant Lamp - Electrical - DIY Chatroom Home Improvement Forum
Old 10-27-2010, 11:24 AM   #1
heat resistant lamp
Hi
I have a ingle nook fire place with a wood burner in it, when the woodburner is on it gets hot within the fireplace..... What I want to know is what type of lamps I could put inside the fireplace that will put up with that kind of heat, and where to buy them from.
I hope you can help with this.
Gary
mrsmith4422 is offline   Reply With Quote
Old 10-27-2010, 12:15 PM   #2
Rewards Points: 82
Contact a place that sells inserts and fireplace supplies. They might be able to help. Personally, I cannot see any lamp or fixture that could handle the heat from the inside of a real fireplace. I could be wrong.
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Governments Renewable Heat Incentive SMurray Green Home Improvement 1 10-24-2010 09:30 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
