Heat Pump Defrost Card Of A Luxaire Unit - Electrical - DIY Chatroom Home Improvement Forum
Old 11-11-2011, 12:23 PM   #1
Heat pump defrost card of a luxaire unit
tHE WIRING ON THE DEFROST CARD HAS BEEN CHANGED AND NEED TO BE REWIRED. i NEED A WIRING PRINT OR DIAGRAM TO REWIRE IT CORRECTLY. THE DEFROST CARD IS NO. 031-01251-000
dOUG DRAPER is offline   Reply With Quote
The Following User Says Thank You to dOUG DRAPER For This Useful Post:
thebew2 (06-16-2012)
Old 11-11-2011, 03:10 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,858
IF YOU CAN'T FIND IT USING GOOGLE, PROBABLY NOBODY ELSE CAN EITHER. YOU COULD TRY CONTACT... [AAHhem. Ooof. That feels better.] contacting the manufacturer to see if they can provide the documentation. You'll probably need to reference the model number of the entire unit, not just that card.
mpoulton is offline   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 06:38 AM
Heat Pump or Newer high seer unit Ed C HVAC 53 04-20-2011 07:07 PM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 01:19 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
