Heat From New Dimmer?!?! - Electrical - DIY Chatroom Home Improvement Forum
Old 02-21-2006, 08:47 PM   #1
Heat from new dimmer?!?!
The plate where my new dimmer switch is installed is fairly warm to the touch.
By no means HOT, but noticably warm.
Cause for concern?
Thanks!
davo420 is offline   Reply With Quote
Old 02-21-2006, 08:56 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,864
No, you are fine.
Reverse this statement:
.....and you should be concerned.
Speedy Petey is online now   Reply With Quote
Old 02-21-2006, 09:09 PM   #3
Contractor
You need to know the capacity of the switch as well as the draw. Most box store dimmers are low amps and if you are trying to pull a cieling array of cans there could be a problem. If I remember correctly, the box store dimmers are limited to 600 or maybe 900 watts.
Teetorbilt is offline   Reply With Quote
Old 02-22-2006, 05:05 PM   #4
"Standard" dimmers are 600 watts. The next step is 1000 watts.
Unless you ask for it or look for it you will get 600 watters. Actually 1k watters are not very common in homes. Some folks do use them for moderate loads to lessen the heating factor.
Old 02-23-2006, 05:17 PM   #5
Been around the block
if you would bother reading the paperwork that came with it you would see that under normal operation dimmer may feel warm to the touch.
eleservtech is offline   Reply With Quote
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 11:22 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 01:27 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 09:57 PM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
