Heat Lamps In Fla. (?) - Electrical - DIY Chatroom Home Improvement Forum
Old 05-21-2012, 02:53 PM   #1
Rewards Points: 2,176
heat lamps in Fla. (?)
my 2 bathrooms have heat lamps in the ceiling. Up north during the winter I would have loved that but not here.
One time I was showing my friends new house to some ppl, and I couldn't find the bathroom light so flipped all the switches till the lights came on. That night he told me I left the heat lamp on and could have burned down his house. So you can see I'm not fond of them.
Would it be easy to replace the ceiling heat lamp with a regular light? Could it be as simple as switching the bulb?
Startingover is offline   Reply With Quote
Old 05-21-2012, 02:56 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If installed properly, the heat lamp will not burn down your house. There are no limits on how long they can be turned on.
If you want to get rid of the heat lamp, you can purchase a regular 65W BR 40 type lamp and install it in the place of the heat lamp.
Old 05-21-2012, 02:59 PM   #3
thanks. I'd feel better replacing them.
Also won't it save on my electric bill to use regular lights instead of heat lights?
Old 05-21-2012, 03:02 PM   #4
k_buz's Avatar
Only if you use the heat lamps. Most heat lamps are 250W so if you used the heat lamps and now replace them with a lesser wattage, you will have some savings, but likely you won't even notice it.
Heat pump is not running on Heat mode frank06 HVAC 17 03-13-2012 03:34 AM
No Aux heat with American Std HP/Trane AH and Honeywell IAQ FREEZING!!!! JackBP HVAC 3 12-18-2010 02:50 AM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
overload circuit with heat lamps? higgins Electrical 4 01-07-2010 08:16 AM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
