Heat Concern From Recessed Light - Electrical - DIY Chatroom Home Improvement Forum
Old 06-02-2012, 02:48 AM   #1
Heat concern from Recessed Light
Hi Folks,
I'm planning to install recessed lighting in my ground floor living room, above which is a bedroom. The living room ceiling has joist spacing of 14 inches, and height of 9 inches, living room is 12x12.
My concern is whether it will be safe to install recessed lighting in such narrow spaces considering the heat generated, which doesn't have anywhere to escape. I'm not sure what is the recommended unobstructed space dimensions in ceiling for recessed lighting in such scenario.
I noticed that in one of the 'alleys' where i will install 2 lights, one side of the joists has electrical wires stapled. Its common sense to keep my light as far away from the electrical wiring as possible. My concern is if the lights have been on for a long time, it might eventually melt/damage the electrical wiring. I know that the electrical wire is generally rated for ~90deg, but just want to make sure whether it is safe.
The recessed lights will be 100 watt bulbs spaced at least 5 feet.
Any advise will be much appreciated.
Thanks,
MAC
MAC2000 is offline   Reply With Quote
Old 06-02-2012, 06:10 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Recessed lights are designed to go into the ceiling. They have a built in thermal overload that will turn the light off if it gets too hot. I don't remember any restrictions concerning how far a can has to be kept away from a wire. I suspect that as long as the wire isn't touching the housing, you will be fine.
Lastly, the max wattage for that can will be determined by the trim you pick out. You may not be able to install a 100 W flood. IIRC, the max wattage on a standard residential type recessed light (based on the trim ring) is about 90W.
Old 06-02-2012, 07:13 AM   #3
Licensed electrician
Rewards Points: 1,630
Typically only a 1/2" clearance from combustibles is required.
The 90 degree rating on the cable insulation is Celcius or 194 degrees F.
Old 06-02-2012, 07:49 AM   #4
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
While the heat from a can light, when properly installed, is really not an issue, you could put your mind at ease by installing a LED lamp. And depending upon usage, it could save you some $$ on your electric bill. The lamps aren't cheap (~$35-$40@) but in the long run would pay for themselves.
JulieMor is offline   Reply With Quote
Hitting a Joist when installing a recessed light? hicksjh Electrical 9 11-22-2010 08:27 PM
Hot air blown out of recessed light penetration deerhunter HVAC 5 10-31-2010 10:54 AM
Recessed Light Install Question kennykenny Electrical 2 12-03-2008 10:00 AM
Recessed light wire size jizzle Electrical 6 12-03-2008 09:56 AM
Remodel style recessed light code question bjstewa Electrical 8 05-22-2008 09:25 PM
